Turn Signal ?
tobor9
This morning my turn signals don't work,but my 4way flashers do,so no bad lights(all LED). Is there a separate fuse for signals? or do you think it's the switch? I know it does not have a flasher but is controlled by the gauge closter and I assume it does the 4ways also. So fuse or switch?
MY money
Is on the switch. I do not believe there is a separate fuse for flasher and turn signals, but check that owners manual in your frunk to be sure. Since you have LED's other things could be going on: I'm not familiar with the LED flasher/turn signal set up. Good Luck :thumbup:
If we are betting..!!
mine is on the led's hookup. They do get touchy but the bulbs are working. Check fuses anyway...:thumbup:
Not the fuse,same one does 4way and clock,both working. I know sometimes LED cause problems but I had them for a couple of years,no problem(they worked yesterday) and the 4ways all work. I'll call Velocity Monday.:banghead:
Well I was right,sort of,it was at the switch but not the switch itself,turned out to be one of the 3 wires was not soldered correctly and had come off. PJ at Velocity re-soldered it and all is good.:clap:
