Turn signal switch replaced
MMcc
I have a 2011 RT-s with 5xxx miles. Turn signal switch started acting up this spring, would not return to center or cancel the lights without lots of hassle. Following some posts here I used spray lube with some success but the problem kept coming back. Spoke to my dealer, he checked it out and said a new switch is required. Brought it in today and glad I did. Most of the plastic has to be removed to route the wires although the plug is easy to get to. They also did the latest updates. New switch is different according to the dealer and I do like the feel. The old one always felt like you were moving the button over gravel. 65 mile ride back home confirmed that it is now easy to cancel the turn signals manually like when doing a lane change, of course it automatically cancels on corners. Thanks to Les and Caswell's Cycles in Mora Minnesota.
