spydernatic
I have this turbine like whine sound coming from my 2017 RTL, it only happens when I change to 2nd gear and with two up and under pressure say through a sharp corner when I have to go through the corner at low revs. Noticed this a lot more this last weekend on the tail of the dragon as we all know a lot of the Dragon turns are low speed 2nd gear corners.
I have done some testing on straight roads and higher revs around 3900 and changed into second it may still be there but can not hear it as clear due to motor noise.
I do have the Doc Humphries belt tensioner on and have had it for over a year but have not done corners like the Dragon.
Any ideas what this can be I am thinking it is the belt tensioner as I had heard the can cause a turbine whine but why only 2nd gear? as it does not happen in any other gear.
Talked to my my local Dealer and they were very helpful and want me to bring it in so their tech can check it out for me.
