Trying to remove the panel that covers the top trunk & extends to saddlebags - help?
rcturner
I have tried to remove the panel from the back but after removing the eight screws, the panel is loose but does not want to be removed. It acts as if it is being held by something around the latch. Suggestions please.
You need to lift the ends of the panels that tuck behind the side bag mounting points to free the entire panel up. As long as you are confident you have removed the correct screws. They(the behind the side bag portion) can be a little tight as the slip by the passengers armrests, but they'll come out just fine as long as you take your time. Hope this helps.
There is a small raised catch that fits under the trunk latch area. Not much of a problem on removal, but you need to pay attention to it on reinstallation.
