BRandRandy
I wanted to use the helmet hooks under the seat but, they just didn't work for me so, I thought about using a stainless steel wire with a D loop at each end. I wanted to be able to sit both helmets on the seat and secure them with the wire to the helmet hook. The only problem was that once I closed the seat the wire just popped off the helmet hooks. I took a bold move and said I am going to try the seat latch post. Wasn't sure how much of the post was above the latch. I didn't need much clearance but, I would hate to get my seat stuck closed. I tried it and pulled the wire taut and closed the seat. It worked.... I was able to open the seat. My next step was to cover each D loop in a plastic material to keep the wires from sticking in my fingers. Got some Plasi Dip at Lowes for about $7.00. Got the 10' of 1/16" stainless steel wire at Tractor Supply but, I think Lowes also has it. It's just designed to keep honest people honest and with the helmets on the seat people are less likely to sit on the spyder. I also found a cigarette lighter adapter for my battery tender on Amazon cheaper that it was from the Battery Tender website. I swapped my fuse from 6 to 7 on the right side so, all I have to do is plug it in. I don't have to attach a wire to the battery. I have included a few pics. Sorry, somehow they came in rotated.
