Trying to identify the type of connector for rear brake?
langevn
Hi, new to this forum and I am looking to make a harness for my brake light on my 2010 Can Am Spyder Roadster RT-S SE5. What I am looking for is the connector type so I can build my own harness for this
BRAKE LIGHT FLASHER MODULATOR
Thank you
Sorry, no idea on connection. Did aftermarket tap in for additional LED's (Rivco SOMA LED) that would modulate while the stock Incandescents performed normally - at least on the ST; I believe the RT are all LED :dontknow:
The long LED's are tail/brake - the short LED's modulate with the brake. Have had quite few positive comments on the combined pattern :2thumbs:
I believe they are 5-position AMP SuperSeal sold on Amazon by several vendors who don't use that name. I bought mine from MUYI but I've also sourced CNKF https://www.amazon.com/dp/B01F57B6N2 It helps to buy the proper IWISS crimp tool. The cheap one that requires two steps is adequate. You're doing the installation correctly by using a jumper rather than using taps that pierce your Spyder insulation.
