Trying to bluetooth music from Zumo 590 - Help?
Baron14y
I admit I am very old and confused. I have a Zumo 590 with a micro SD card installed. I have music on the SD card. I have a Sena SMH10 intercom on my helmet. The Sena bluetooths automatically to my phone and I can listen to music from that. However, I have not been able to figure out how to connect the Sena to the Zumo SD card to listen to the music on it. It says it can be done. The Zumo connects automatically to the Sena and I can hear directions through it, but no luck connecting with the SD card. What do I have to do to make it work?:banghead::popcorn:
If you have paired your SMH10 to your Zumo in accordance with the instructions in your SMH10 User's Guide, in the Zumo App menu, select Media Player. In the upper left corner of the screen touch the symbol of two audio cable plugs and put a radio dot in the MP3 player. That will set you up to select and play the MP3 files on the SD card.
I will give it a try. Thanks.:bowdown:
Glad to help. In my experience the closer we were to the point of the spear the better we worked together. The infighting is the purview of all the brass in Washington.
And the politicians in Washington, most of whom have never drunk a drop of GI coffee.
