racoon
Well-known member
Have either of you found that the Garmin head unit moves or settles from road vibration? I like the adjustability of the ball mount, just curious if it can be tightened enough to keep everything in place while riding.
The picture I posted above is the mount on my 2024 S2S and is used with a Garmin Zumo XT, which is a motorcycle specific GPS.Oh and it will be going on my 2024 S2S once I get it back from the screen issues....so if anyone has connected one to the 2024's is there a power port connector on the right side under the panels like the older 2023's?
Also pics of mounts would be great..not on handle bars maybe above on the screen surround?
Yes there is the GPS power port on the right side just like the 20 t0 23 rt's.
There is one a power port on the right side of my 2024 RT S2S, behind one of the panels.
But despite buying the "Y" adapter from Lamonster and following their video directions I have been unable to get it to power my GPS.
That's why mine is being powered by the USB port in the glove box.
I found that the Touratech mount does vibrate around a bit more due to its size and weight. Also, the longer the RAM arm, the more movement you're likely to get. On my new Zumo XT2, I now use a MotoPumps lock and the shorter RAM arm. I also have a RAM arm key lock, but I'm currently using the 5 pin RAM lock now. Much less movement, albeit not the vault like lock of the Touratech.
RAP-S-KNOB3-5U RAM Pin-Lock™ Security Knob with 5-Pin Pattern for B Size Arms
But they do! Your Operators Guide clearly says you have Apple Carplay, which includes navigation!I'm a little disappointed that BRP doesn't at least have a basic nav app built into the bike like most other manufactures flagship bikes have.
When you connect your iPhone to CarPlay, you can get turn-by-turn directions, make calls, send and receive messages, listen to music and more.
So, looking for some opinions here. I currently use my phone on a handlebar mount with Rever or maybe Waze. I don't use BRP Connect (or Go or whatever it is now). The big issue I have is seeing the phone screen with the glare from sunlight. The boss is suggesting a Zumo, but it's a fair chunk of money, so I have a few questions.
Will using a Zumo eliminate the glare issue?
I've been using a Zumo for years, I have never had a glare issue.
Can I use Rever with the Zumo for turn-by-turn directions?
Why? The Zumo will give you turn by turn directions.
If there is a specific destination punched into the Zumo, and we go off route, will it guide me from wherever I am to that destination, or will it try to direct me back to where I left the original route first?
It will try to direct you back to your original route, once you are past the option to do that, the Zumo recalculates from your current location.
Is the screen clearer than a phone screen?
Clearer? It's a very good screen, shouldn't be an issue.
How does it handle not having cell service?
It doesn't use cell towers, it is satellite communication.
Any wiring or installation issues?
Nope, all it takes is a 12v connection. Lamonster sells a wiring harness that is as plug and play as you can get.
Does it work with gloves?
Yep, no issues with gloves.
Integrate with the Cardo systems?
Yes, it works great.
Connect to Spotify?
See previous answer regarding satellite. There is no way for it to receive spotify.
SO I'm wondering if it actually does this, do I need my phone at all except for calls....
Anyway, thanks for your patience....
Mike
