Trunk that will fit BRP quick attach backrest
Nice job. I see that you followed the idea that some of us did in removing the ugly orange trim strip and painting it to match your Spyder, Big improvement. Could you share the dimensions of your brackets with us so we don't have to start from scratch?
The Fusion yellow doesn't really match the spyder orangish/yellow paint, so I decided not to paint the raised section of the trunk lid.
The dimensions won't do you much good but here they are. The "L" bracket is 1/4" thick steel in any width wide enough to drill a bolt hole in it. 1.75" X 12". The strap brace is 1/8" thick strap steel and is 15" long, but because of the bends in it, you'll have to figure that out yourself. It's rather complicated bends. You should consider making a hole in the bottom rear of the sport rack housing instead of going under by the inner fender cover, tap the hole and run the brace directly to it for more stability if you have the resources. I may modify mine.
