Trunk sping
More like the James Bond's Aston-Martin passenger seat... :clap: (remember those movies...?)
I acually still have a Corgi model of that car. (The gold Aston MArtin DB5)
It has an ejector seat and a bullet proof rear shield and machine guns in the front.
I think I would like the machine guns on the front of my spyder (when I get it) Way better than a train horn!
picture.php
Trunk latch
The trunk on my RTS doesn't close properly. It doesn't seem to "latch". I've tried alligning the top correctly and it still doesn't close properly. Any suggestions?
Seems to be a common problem. I've seen it a few times now. The latch can be adjusted so it works better. If you can't get it, ask the dealer to adjust it for you. The bearclaw latch is slotted front and back, so can not only be raised and lowered, but tilted either way. Seems to need the front raised fairly high, with the tight new gaskets and the trunk liner. The rear may have to be higher, too, to move the claw opening forward, or lower to move it back. A little grease will help a lot. I prefer non-staining silicone grease for this. One last hint. With all the tight rubber seals, the storage compartments need to be closed, then pushed firmly to latch. The airtight seals fight back a bit. You don't just slam these or drop the front lid closed, like on the RS.
