Tried to pull up codes on 2011 RT-5
ronII
Tried to pull up codes by using the MODE-SET-TURN signal cancel, but it didn't bring up anything other than standard screen 0mph and mileage, I don't know if it should be in a certain mode to start off. This is my first time trying to get codes so it's all new to me .
Here's the thing....
You have to do it when it happens or before you turn the spyder off. If you don't have the spydercode app you should get it . it will tell you how, what codes are there and what to do about them. once you shut down they will be stored and only accesable with the buds program....:thumbup:
By pressing the three buttons at the same time the screen will go blank if no codes are present.
Otherwise they should be listed.
If your screen doesn’t change it could be you are not pressing down all at the same time.
