gkamer
Sadly passed away, December '23.
I've been trying to pull up any fault codes on my 2018 RT Limited. From what I've read you should hold down the mode button, set button and press the turn signal cancel button all at the same time. My Spyder does not have a Set button, only mode and parking brake. Is the parking brake button also the set button?
I noticed the parking brake light (red light) was blinking as I was riding. The manual says that indicates a brake failure, but my brakes were working fine so I want to see if there is some other error/fault code on the bike.
