Tric Led A pillar lights
fire207
Does anybody have any pics to share on installing the Tric Led lights on the A pillar , top and bottom. I am not really seeing any way to hide or safely attach the wires away from the moving parts, hoping someone can help me with a different view, thanks
I hope that this doesn't sound too silly :shocked:...
I'm not following what you mean by "A pillar"; can you be a little more specific as to it's location?
Installed them last week.............
Put mine on the lower part of the "A" frame. Found I needed to reverse them (glad I hadn't stuck them on). Wires should run in under the frunk. I threaded mine through the lower "A" frame cover and up into the wiring under the frunk. When you raise the Spyder up and get under it, you'll see two (2) connectors, each with an orange and white wires. These are the ones you connect Reggy's connectors into. Then you can test and cable tie the excess wires or cut them shorter.
Jim
I have a RT and the directions stated using to tip light connection, I got under there again and there are a couple of possible places, I dont have fog lights so I might look there, anyone with a RT chime in anytime....:pray:
Under and to the rear of the upper A arm is the connector for the tip lights. That's the one needed for the day running lights. I put ours on the upper A arm.
Reread your post. Are you installing a set on the upper and lower A arms?
