h0gr1der
For those of you wondering (Non scientific measurements);
Tri-Axis bars adjust Forward and Rearward , plus higher and lower, and any combination of the two.
The Maximum and Minimum width remains constant for any height setting.
Max Width (Forward) is 33.5" and Min Width (Rearward) is 29.5" Your hands will each be 2" closer to centerline at the rearmost setting, at any height.
The fore and aft span changes with the height setting of the bars.
Lowest setting fore and aft span. Forward position to mirror 15". Rearward position to mirror 19". At the rearmost position, your hands will be slightly less than 19" from the mirror enclosure.
Highest setting fore and aft span. Forward position to mirror 12". Rearward position to mirror 17.5". At the rearmost position, your hands will be slightly less than 17.5" from the mirror enclosure.
The height span changes in relation to the Forward and Rearward position.
Height from floorboard at lowest setting Forward 32.75" and Rearward 30.25".
At the low bar position, all the way to the rear, your hands will be about 30.25" above the floorboard, and 19" from the mirror enclosure.
Height from floorboard at highest setting Forward 35.5" and Rearward 34.5".
At the high bar position, all the way to the rear, your hands will be about 34.5" above the floorboard, and 17.5" from the mirror enclosure.
The height adjustment is made with an 8mm hex wrench, about 12 rounds from highest to lowest. A good 3/8" ratchet helps with this. Make sure you loosen the 2 front bolts before adjusting the height with the single rear bolt. Loosen the front 2 first, tighten them last.
