Transmsion Shifter
lesleyh
I goofed yesterday and stomped too hard on trans shifter and I think something happened inside trans. I can only get Rev, 1st & 2nd. It also slips from 2nd back to neautral. will not upshift to 3rd or 4th, 5th. I need some tech support please. I also need a manuel. Thank You. Les.
Sounds like you may have bent something inside the clutch assembly. Best you let the dealer take a look at it. JMO
Lamonster may be on to the real issue. When I installed the new shift lever for the floorboards I had to adjust the linkage below as I was only getting the lower gears, then over adjusted and only got the higher gears - in between was the sweet spot for ALL gears. Think it is a 10mm wrench to adjust it.
