Bluehole
with each push of the paddle-----sometimes. 2014 RT-L SE6
Changed oil and filter this past Sunday. Started the bike up after pouring 5 qts in and let the oil light go out---let it run for a few minutes,
pulled the dip stick/wiped and inserted the stick and pulled it out again. Showed oil to be half way between full and needing to add. Buttoned
up everything and went for short ride to warm things up--came back and checked again---showed same as above. Went for about a 35 mile
run and when I got back let the engine idle for 2 runs of the radiator fans plus a little. Checked oil and added enough to bring it to the full mark.
Went for another ride---this time longer yet and as I was coming back home I decided to go thru town and got stopped at just about all the stop
lights. As I pulled away from each and pushed the paddle to up shift it was accompanied by a clunk in every gear. Now this has been going on
for the last 5000 miles but I figured it might quit when I changed oil---it has not. The transmission does not care how fast or slow you are going
nor does it care what the RPM of the engine is---if it wants to clunk it will. It does not do this ALL the time only when it wants to surprise you. It
most often happens in the first 4 gears and is then silent for the 4-5 & 5-6 shifts. Sometimes it will let out a big ole clunk on the 1-2 shift and then
the rest will be smooth & quite. I forgot to mention that from a cold start in the morning, the machine produces crisp, clean, smooth upshifts until
the engine oil has reached operating temp. By that time I am usually on the highway out of town so I don't notice the harsh shifting until I reach stop & go
traffic somewhere.
All downshifting, whether manually or by computer has been smooth and mostly quite to this point. I have read on SL of a couple of guys complaining
of the same thing but but nothing about the cure.
I am using Amsoil 10W-40 & put in a new BRP filter with all new "O" rings. The bike just turned 20,000 miles. There is no jerking that I can feel, just the
clunk noise--the same noise that you hear when putting the bike into 1st/reverse gear after a cold start except it is doing it in the first 4 gears whenever it
feels like it. I did not change the HCM filter as it is not required until 28,000 miles. There is no oil foam on the dip stick when I pull it. When running down
the road the machine sounds just as normal as it always has.
Any comments on this one???
Thanks,
traffic somewhere.
Thanks,
