Hi. New to the group bbecause I just bought a RT A&C. I am a full-time RV'er, so I am looking for a way to transport the Spyder. Whoo has found a trailer specific to the Spyder? Any:2thumbs: other recommendtions?
How about using 10' ramps.Hey MouthPiece, my 6x12 trailer looks similar to yours but I have the same problem trying to get the RT-S up without hitting the front. Would you explain how you get it up using the jacks you installed on the front. I'd like to do the same. Thanks!
I don't have an RT but I had a trailer built to fit my RS. There are tire pockets in front to help stabilize the :spyder2: when traveling. I also had the rear gate done in two sections to accommodate the steep angle and low clearance of the RS. The trailer has 15" tires so it handles great at highway speeds. The trailer cost $1800.
We live in our RV & have a Spyder that we have decided towed behind it for 2,000 miles & it works very nicely...you were have also towed it behind our SUV once. It is a 2016 Drop-Tail trailer. It is bif enough to carry 1 Spyder or 2 Harley Davidsons. We are interested in selling it to get a larger trailer that we can tow both our Spyder & our SUV on together. We are located in Lakeland, FL. Let me know if you are interested in buying it.
Interested... Questions
-what are dimensions.... particularly width?
-how many pounds will it carry?
-two axle?
-7 blade wiring... all lights working
-How much?
-Where are you located for pickup or ship?
Ken
Deck width is 7 ft., deck length is 7'6", will carry 2,000 lbs., single axle, American 3,500 lb. tortion bar suspension, LED lights all around, 4 pin flat electrical connection, 2 in. ball required. $2,700 and we are located in Lakeland, FL. Can private message if interested and would like pictures. Thanks.
Bruce
Where did you have trailer made?
Thinking of towing my Spyder behind our fifth wheel.I have a newer 5th wheel with a receiver hitch that has very limited weight capacity. I have an RV trailer that I could load the Spyder on. Does anyone have an idea of a dolly that I could tow that would handle the tongue weight of the trailer?
