I've never had to trailer mine, but if I ever do it will be in 1st gear, park brake on, strapped down with 4 straps. Why would you take any chance of it moving if one of the options failed? A few good wheel chocks would be in place. that's my .02
Why? Doesn't your chime quit after about 20 seconds, like mine? :shocked:On my 2014 RTS - SE6, there is a warning chime if you shut off the key with the parking brake off. If a person wanted to trailer without the parking brake, they would need to disconnect the battery to silence the chime.
H2O
As impatient as I am, I never waited that long to see if it would quit on its own. I couldn't stand the noise so I turned the key back to the on position while I was doing whatever it was I was doing at the time.Why? Doesn't your chime quit after about 20 seconds, like mine? :shocked:
Mike( Blueknight911) tied down my 2012RRTS-SE5 the way you described above and my :spyder2: did not move on snowmobile trailer. DeannaAfter reviewing many of the trailering threads I decided to follow Mike's advice and strap all three tires u-haul style. I have a 7x12 enclosed trailer with ramp door. I chose a position over the axle allowing most of the 1000+ lbs to be over the single axle rather than further forward making excessive hitch weight. Attached photos show how I did it. Real wheel used 33,000 lb ratchet strap, front wheels used 2 In 1600 lb straps. Anchors are 3/8 in 6000 lb bolted through 3/4 in advantech floor with 3/8 x 2 in carriage bolts and 1.5 in flat washers and a lock washer. I have not trailered it yet except for short test run, so if anyone has advice as to how I can improve or have errored, please comment. My initial impression is that it is pretty secure and not going to move much. I plan to leave trans in neutral with parking brake on.
