trailer wiring harness for 2010 RT
Callahanjc
Is it safe to say that the only way your going to have lighting for your home made or aftermarket trailer is to use
BRP parts, or is there a way towire the roadster with aftermarket wiring:yikes:
Spyder End:
I don't know that anybody has tried to directly wire a trailer connector and aftermarket module, as owners use on their RS's. It should work, unless Nanny shuts things down, but there is not good place to bring out a harness or mount a standard trailer connector. For those using the BRP hitch, it comes with a trailer harness that includes the connector/module.
Trailer End:
That creates a new problem, you need to connect to the 9-pin (7 pins used) connector. The easiest way is to utilize a BRP trailer tongue harness with the matching connector, but the Deutsch connectors, pins, and crimping tool are available elsewhere. Whichever way you go, I highly recommend the use of the positive locking Deutsch connectors, which are also waterproof.
