OverHillAndDale
I bought a used Aluma motorcycle trailer (MCTXL) - very well maintained and in good condition, about 11k miles on it. It's got the configuration where you can pump in bearing grease until it comes out a hole, and the previous owner said he pumped it full of grease every few thousand miles.
Question - Should I replace the bearings? It seems to me that the load on these bearings would have been small even if the trailer was fully loaded since the trailer and associated loads would be less than 200 lb/bearing. However, I'd hate to have a wheel lock up because I was too cheap/lazy to replace some bearings.
Thoughts? What kind of life should I expect from these wheel bearings? (The manufacturer is naturally non-committal: "Replace them if you think you should.")
