Trailer Adapter
Yes, only the LED part of the light will be functional. The use of the separate turn signals were abandoned after 2010. Don't go by the wire colors in the back (behind the underbody connector), they are different.
Ok, thanks. I was just making sure what I had where...
JT
Ok, I got the 4 pin trailer tongue harness and it has a green, yellow, white and brown wire. I have the 2010 wire colors sorted out just need to verify the 2012 colors so I can splice the plug on.
Thanks
JT
Ok, what I have so far with the meter is:
Brown = Running Lights
Yellow = Left Turn/Brake
Green = Right Turn/Brake
White = Ground
JT
For those following along this is what I ended up with using a 2012 wiring harness and splicing it to the 2010 connector under the trailer tongue.
[TABLE="width: 500, align: left"]
[TR]
[TD]2012 color[/TD]
[TD]Function[/TD]
[TD]2010 color[/TD]
[/TR]
[TR]
[TD]White[/TD]
[TD]Ground[/TD]
[TD]Black[/TD]
[/TR]
[TR]
[TD]Brown[/TD]
[TD]Running Lights[/TD]
[TD]Brown[/TD]
[/TR]
[TR]
[TD]Yellow[/TD]
[TD]Left Turn/Brake[/TD]
[TD]Orange[/TD]
[/TR]
[TR]
[TD]Green[/TD]
[TD]Right Turn/Brake[/TD]
[TD]Red[/TD]
[/TR]
[/TABLE]
JT
