TPMS
I do not use ride-on myself but my bet is this: If you put the stuff in and wait a few days for it to spread around and do it's thing. Then add the sensors, I think you will be fine. The sensors are sealed but since it obviously has a pressure plate inside to sense pressure, if something gets in that it might keep the sensor from reading. But based on how I know ride-on works, if you do what I said about waiting, I bet it will be OK. I mean ride-on doesn't foul your stem valves so probably wont foul the sensors either.
I am in contact with Bob Much and will follow up with you on this.
FYI, I carry a tire repair kit with me that includes emergency air. I also carry a small compressor. If I get a nail or something I will plug the tire properly. I am just not a ride-on believer even though I know many are. I just have my way and have stuck to it.
http://store.valueaccessories.net/StreetTirePremiumRepairKit.aspx
Bob
My purpose for Ride On is for the dynamic balancing aspect, not so much the puncture repair. I've had it in these tires for two months, so I'm sure it's settled in by now.
According to Ride On technical information on their website, a TPMS sensor will work fine as long as its hermetically sealed. I have asked this question of the
FOBO people and am awaiting a response.
Pam
Bob Much should get back to you on this but I also talked to him about it. I am sure he is asking the folks in Taiwan to be sure but I bet you will be fine. Takes a day or two to hear back from the manufacturer but they are really good at responding.
Bob
Bob
I've been emailing back and forth with someone named Sameer.
Pam
FYI to keep you entertained....
So you know a user here on Spyderlovers when I first did the video asked if they could update the APP to allow a sensor for the RT's air shock for monitoring etc. So after my video they did add a 4th sensor you can get for the airbag along with abother choice in the menus for a Spyder with air shock :)
It does work but because of the large pressure changes it will give warnings if you don't shut it off. But it is cool to see if your shock air bag is leaking or changing.
So if you also want that add a 4th sensor.
Bob
Fobo sensor are made in Malaysia. I buy my 3 TPMS sensors directly from the company in that country and I received them here in Quebec City 4 days later.
Very useful....
Another little follow up video I did.
Bob
In the video you mention that you set your front tires at 19 and "It's high for the spec". I don't get that. The spec for the front tires is 20 according to my manual. Unless maybe it's differnt from one model year to another? :dontknow:
I have a 14" rim due to mine being a 2011 RTS. They changed the tire size in 2013 with 15" rims. Nominal pressure is 17 as I recall for my 2011 model. I prefer to run 19.
Bob
I have found that if you email the FOBO log file to yourself and open with a spreadsheet (excel / open office) you get a very detailed record of temperature and pressure for each sensor. Get a little creative and add two columns to convert the KPa and *C to PSI and *F.
Small sample attached.
[TABLE="width: 455"]
[TR]
[TD]Date & Time[/TD]
[TD] TPU#[/TD]
[TD] Kpa[/TD]
[TD] PSI[/TD]
[TD] *C[/TD]
[TD] *F[/TD]
[/TR]
[TR]
[TD]2015-08-02 16:16[/TD]
[TD="align: right"]1[/TD]
[TD="align: right"]134[/TD]
[TD="align: right"]19.4[/TD]
[TD="align: right"]42[/TD]
[TD="align: right"]107.6[/TD]
[/TR]
[TR]
[TD]2015-08-02 16:59[/TD]
[TD="align: right"]131[/TD]
[TD="align: right"]19.0[/TD]
[TD="align: right"]32[/TD]
[TD="align: right"]89.6[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="align: right"]3[/TD]
[TD="align: right"]225[/TD]
[TD="align: right"]32.6[/TD]
[TD="align: right"]40[/TD]
[TD="align: right"]104[/TD]
[/TR]
[TR]
[TD="align: right"]228[/TD]
[TD="align: right"]33.1[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="align: right"]4[/TD]
[TD="align: right"]129[/TD]
[TD="align: right"]18.7[/TD]
[TD="align: right"]37[/TD]
[TD="align: right"]98.6[/TD]
[/TR]
[TR]
[TD="align: right"]33[/TD]
[TD="align: right"]91.4[/TD]
[/TR]
[TR]
[TD="align: right"]34[/TD]
[TD="align: right"]93.2[/TD]
[/TR]
[/TABLE]
Bob
You're right Bob, many people don't know what their tire pressures are doing as the tire heats up, but it is just a tad more confusing than you think!! And your advice towards the end of that link above will do exactly the OPPOSITE of what you intended! :opps: Sorry.
The more your tire pressure is too LOW for what you are doing/asking of it, the greater the heat increase & therefore the MORE the pressure increase as you go!! It all comes back to the flexing of the tire carcass & the way the air inside it gets heated & expands when that happens - more flexing (say from lower tire pressures) and the hotter things get, so the greater the pressure increase! So if you want to make sure your tire pressure doesn't go up too high, you hafta ADD air pressure, not start lower, that'll only make your tires hotter & more likely to blow!!
Tire pressures & temperatures are definitely not as simple a thing as many believe, but it is something that can impact on things like tire wear & longevity, traction, handling, ride, and just about anything else you can imagine. But leaving out all the complexities & confusing that discussion would bring, at its simplest, for the 'optimum' balance between all those, you really want your tire temperature to increase by about 4-5 Degrees C and no more from what it is when cold, before you start riding - and funnily enough, that works out at being a pressure increase of about 4 PSI once your tires are up to temp. So to get the 'best' from your tire, especially if you are running automotive tires, you want to aim at a 'cold start' pressure that will give you a 4 psi increase after an hours ride. Most manufacturers of cars & tires, as well as drivers and owners, racers, tire techs, etc, have used what's become known as 'The 4 psi Rule' to help with this - Cooper Tires even put out a guide explaining this 'rule of thumb' for 4Wheelers, the 'Cooper Tires 4WD Drivers Guide', altho they do suggest using it only on road, but it applies anywhere, on or off road, just as much as it applies to the tire pressures you use for your cage & your bike as well as their 4WD's.
There's a helluva lot of discussion around about this little 'rule of thumb', altho in recent years most of it has been generated by 4WD Forums, but it will help you & anyone else who wants to bother with it to try and get the best from your tires; and once you understand how it all works & applies to what is happening in & to your tires, you can get more from them and your TPMS too, as well as making better educated decisions about how to prioritise one aspect of your ride or tire use to suit you/your needs (just like you have by choosing 19 psi for your front tires for the handling, altho that might come at a little cost in terms of tire life or ride/traction) Just stick 'the 4psi rule' into google & start reading. I apologise in advance for the seemingly blatant advertising (you'll see) but all that info (& typing) is already out there so why not use it, & besides, I'm retired now! ;)
Sorry about out the epic read. :opps:
Nope. This is what I see when I click on the Buy button.....
attachment.php
FYI I see why you could not find the trike option. Look at the bottom of the page in your image.
You are on a Malaysia web site called Salutica which is a seller in Malaysia. Seems they even copied Bob's site! Not good and no wonder it looked confusing to some of us.
That is not the fobobikesales.com site that is here in the USA and the USA distributor and his name is Bob Much.
If you don't get an answer from them for your ride-on question, I would check with Bob before you purchase.
Bob
Got Mine Today
I have the FOBO for my bike and for my van. They give you piece of mind that's it. If your tire is low or gets low it tells you. There is 3 alarm levels so if you have a big problem it tells you, it alarms at 10% low, my BMW only tells you at 23%. If I'm towing the bike, I take the unit off the front tires and put them on the trailer. I had bought new tires for the trailer and was coming back when the alarm went off, WTF the valve was leaking and I would have lost the tire if I hadn't of caught it. When I am pulling the bike's trailer, I can take 2 off my van and put them on the trailer.
To me they are worth it, check the pressure on my smart phone and take off, checking the pressure especially on the rear is a pain.
Have had the FOBO bike system for a quite a while now. Love it! No issues with it! Not annoying crap!
I was one of the first to put this on a Spyder and for me, it is piece of mind and a simple way to check your tire pressure before going for a ride rather than getting down there to check with a gauge especially the rear tire which is a pain!
Bob
Thanks, guys, for these posts, and also to Imadson for starting this thread. I've used a TPMS on my motorhome for years, and it has saved me a LOT of inconvenience and aggravation over the years. I've always wanted one for my RT, but didn't know they made them small and light enough to be used with rubber stems until I ran across this post and learned about the FOBO Bike system. You can see in the picture below how small the sensor really is - a lot smaller than other TPMS sending units I've used on other vehicles.
After reading the comments here, and reading Bob's thread here in the DIY forum (which includes another excellent Finless Video), I put in my order. It arrived today, in less than a week. Installation and syncing them up to my smartphone went flawlessly - and it's amazingly accurate. Now it will no longer be a pain (on my 70-year-old arthritic knees) to check the tire pressures on each tire before every ride, and even monitor the pressures on longer trips while riding. I'm lovin' this thing. I think it's going to be one of my favorite farkles before long. :thumbup:
Also I'm betting it'll pay for itself, maybe a few times, in longer tread wear over the life of the Spyder (because up until now, I have NOT been checking the pressures as often as I should).
Here is a screenshot of my smartphone with the app running, and a picture of the sensor installed on the tire....
attachment.php
attachment.php
The three shaded fields are telling me that the readings shown are NOT in "real time" because I'm currently in the house and the Spyder is outside in the garage, out of range. If they were "real time" readings, the fields would be white. (I'm running the rear at 25 psi, since it is a Yokohama car tire.)
Glad your liking it Rob!
I like it so much for the reasons you state, I would never be without it on any motorcycle now.
It's amazing technology compared to other systems out there which are usually just warning systems and not real digital air pressure readings in the palm of your hand like FOBO is.
Bob
