top side panel removal
rhoule1
I am new to this forum. I just purchased a 2014 RT. Trying to figure out what kind of tool I need to remove the fasteners on the top side panel. It's not hex or torx. Any suggestions?
Appreciate any input.
Rhoule1
most bolts are torx or push pins if you are talking about the two chrome bolts on the bottom part of the panel, they are not bolts, they push into grommets
DO NOT try to unscrew those two silver torx screws. As John said they are pushed into the grommet. Read your manual and learn how to remove the panels correctly
Top panel Fasteners
Hey guys, thanks so much for the feedback. I did look at the manual but must have missed that. I will get a shop Manual. Thanks again.
Are you talking about the panel you remove to get at the oil filter? If so, the black screws are Torx. I picked up a set from Harbor Freight couple years ago...pretty cheap. Haven't tried it but theres one in the tool kit that might fit.
