Top Case SPeakers
shoes8
Hello! I have a 2016 F3T that we added the top case to a little while ago. I would love to connect the rear speakers in this top case, however, it looks as if the required top case speaker part has been discontinued. I believe this is what I need: Can-Am Top Case Speakers Amplifier Kit for Spyder F3-T Part #219400769.
Is there a work around for this or am I out of luck? I could start calling all the dealers to see if they have a random leftover but thought I would try this forum first. Thanks for any input!
I don't know why you would need a separate Amp .... My 14 RT has Four 5.25" speakers and the OEM head-unit puts out plenty of power .... I can't turn the volume past 3/4 because it would hurt my ears .... it's not a distortion issue , the sound is great ..... check a wiring diagram and see how BRP did their's ..... Mike :thumbup:
When I bought my 2016 F3L it came without the top box/top case. When buying the (then) optional top box with speakers I also had to purchase the amplifier to go with it. For the price they charged it should have been gold plated with platinum knobs, but no.
There's no workaround. If you want the speakers, you need the amplifier to power them.
From everything that I have read, they only did this particular harness for the 2016 and 2017 F3T when people added on the topcase. I haven't found any wiring diagram that shows another option. Thank you for replying! I appreciate it.
Thanks Andrew... that is what I think too. The topcase is very pricey to not have a direct connection without spending a couple more hundred dollars. Thanks for responding.
