That wear pattern is indicative of too much air pressure. It "ballooned" the middle. Forget the tire mfg recommendations. Your only 1/4th the weight of a car.
Actually, that wear pattern
on a Kenda is
NOT indicative of too much air pressure, it's the extremely lightweight construction of the tire and its width that causes the centre of the tread to balloon out as soon as they start rolling - they'll even do that with only 5 psi in them!! And yes, I have done that to confirm it still occurs - and I don't recommend it to anyone!
The Kendas, and all their clones, including the 'new' XPS tires (that are still basically just the same old construction Kendas, only with a different tread pattern!
) actually
NEED those higher pressures in them to carry the load of a Spyder, even tho it's much less than that of a car.
I'd surmise that it may have even been a deliberate choice on BRP's behalf when specifying the tires - they likely directed Kenda to make them out of lightweight/less strong material so that they'd still
NEED about the same pressure as most other car tires when run on cars, so that the Spyder owners, who can't possibly be smart enough to learn what is the best pressure for their Spyder's tires instead of their car's tires, won't hafta think too hard; and also, any '
straight off the street and basically unskilled' tire fitting tech won't need to do anything different to whatever they'd normally do when fitting any other car tire onto a rim, or think of putting any other pressure into them!!
There's really not much you can do to stop a Kenda/clone rear tire from wearing in the middle except maybe for riding so gently that it never rotates fast enough to throw that centre strip of tread out - they pretty much
ALL wear out in the centre cos once you start going over about 30 mph, cos once they start spinning that fast,
THAT'S BASICALLY ALL THE TREAD THAT'S TOUCHING THE ROAD SURFACE!!
However, the '
Lower pressure to avoid that tread wear pattern' thing certainly
DOES come into play if you run a 'real' car tire on your Spyder, one that is manufactured well/strong enough to carry the weight of a car, ie. much more weight than a Spyder!! That's why you only need about 18 psi in just about any other 'real' car tire fitted to a Spyder - as you alluded in your post Mr Bruce, the stronger car tires just don't
NEED that sort of pressure to carry the lighter weight of a Spyder, they're
waaaayy more than strong enough to carry a Spyder with less pressure in them, hence the reason for running them at about 18 psi when fitted to a Spyder - anything much more is gross over-inflation!
