I am thinking it is a lack of shock spring pre-load on
them .
What I learned so far from this site and trial & error
1. The stock Kenda tires only have a one ply side wall. While that may work for a two wheel motorcycle tire, it certainly will have a difficult time dealing with the lateral forces generated by a Spyder.
2. More air pressure can help stiffen the front tires - to a point. The Owners Manual recommends 18-22 psi. I now have 22 psi and it did help, since the Spyder was originally delivered with 18 psi. BTW the tires are labeled for a min. of 15 psi and a maximum of 30 psi. So there may be some additional pressure possibilities with increased center tire wear and some loss of edge traction.
3. The 2014 RT's generally handle better than previous stock models and this, with a little higher air pressure up front may good enough for some folk.
4. The next step generally involves a RonBar, but it could also involve "car tires" with stiffer, multiple ply side walls as an intermediate step. Either or both of these solutions could make most people happy.
5. Last, and most expensive, is the shock and spring upgrade.
Any other thoughts on the above????
Bob & SpyDee
