safecracker
Well-known member
Hello everyone. I had this past Friday off and I just received my new Kuhma tire. Before tackling the tire removal i have watched most of the videos that relate to this procedure. WHile looking at the manual I noticed that in the chasis section, you could remove the rear fender. So I decided to try it. WOrked great. First you ahve to remove the upper portion around the latches that open the trunk and side bags. Now you can remove the 9 screws that hold the rear fender on. Once fender is off there is alot more room to remove tire and you don't have to jack the rear tire more than an inch off the floor to remove it. It made removal and reistallation of the tire alot easier. Hope this helps. Bruce
