stevehendo34
2008 Spider GS I just bought 19,000 miles.
I kinda goofed and bought it without looking well at tire wear or driving it above 50 mph.
Got it on the highway and was getting some wobble at 55+ mph.
I looked better at the tires, the left has outside wear and obvious toe in.
I set up a jig to get alignment close, and yes it was ~1/2 inch off.
Built the jig with help of a mill and adjustable screws on top of horizontal members of the jig.
I looked at tie rod on right tire and saw 5 threads out of lock nut.
I decided to start there and after losing the lock nut on the left tie rod adjustment I began to adjust the toe in out of this tire.
Oddly, after a few turns the tie rod bottomed out with 3 more threads showing than on the right side.
The toe in improved by 1/4 inch but would not adjust any further, it's like the tie rod is too long since it bottoms out.
Locked the adgustment down and test drove it. The wobble is much better, actually mostly gone.
There is definitely something goofy - the minimum number of threads showing on that tie rod is 8 while the no tire wear side is set at 5 threads.
I'm sure that if I could adjust the bad side to ~5 threads the toe in would be nearly perfect.
A laser alignment is not going to adjust toe on a rod that is set to it's minimum length.
Bought some new tires and will try again to get it close with jig.
Anyone have comments on why I can't adjust the left side toe in enough and right side threads go much farther into the end of the tie rod? Isn't the spec called for 0 toe in on both sides like most road cars?
Camber on both front wheels are nearly identical, even though there is no adjustment.
Telling me to take it to a certified Can-Am mechanic will not be helpful!
