throttle Stuck
Ok so after a week in the shop fix they had for my throttle
didnt work so they had to order a new throttle tube
said it's fixed but won't be able to get it until Monday
:gaah:
This doesn't sound like the problem noted above but is something to watch out for. I use the RAM mounts that are mounted to the handlebars with a hose clamp and as usual, I tightened the hose clamp to just below the point of breaking. On the first ryde the throttle stuck open! I reduced the tightness of the clamp on the throttle side and no more sticking and the clamp was still plenty tight.
This is an example of the clamp:
attachment.php
Mine is bone stock right now
what was happening is twist throttle
1/2 to 3/4 open take your hand off and
it stays in that position.
Its a 15 rt limited I appreciate the input
though
Well after 2 weeks in the shop the dealer
brought my spyder the 2 hour trip home
just to load it back up and take it back
for the same problem :banghead::banghead:
Ok so the latest in my throttle delima
is my dealer and can am are going
back and forth as to what's going on.
They are now replacing the switch housing
thinking they got a bad batch from the
supplier. Been in the shop long enough
begining to think I bought a Harley :roflblack:
Sorry just had to throw that one out
