Throttle return spring.
2blueranger
I removed the end cap of the throttle and the spring came out. Can't seem to get the spring back in the little hole and slot at the same time. Does anyone have a way of doing this? Thanks
Directions
Here is the illustrated instructions for the installation of the spring on the throttle handle, if you do not have them. I don't know of any special trick, but I hope this helps. throttle handle.jpg
Thanks for the info, but my problem is the hole and the slot don't line up. I have tried to wiggle the spring every which way, it just won't go in the little hole.
