Thinking of putting Fox shocks on my wife's STL
You're welcome, if needed, you can put as many as two spring rubbers in each shock, one on top and one on bottom but I think one set will work for your wife and it's hard to beat the price, much cheaper than investing in shocks to prevent the bike from bottoming out, I was impressed with the difference in handling as well :thumbup:
I put them on today and we went for a 4 hour ride and my wife said it didn't bottom out once.:thumbup::thumbup::thumbup:
Thanks again Jeff. Saved up close to $400.
If your coming to SpyderQuest, Supper is on us. We have a white STL and a Valkyrie Interstate.
Brian
Brian
Happy it worked for you and your wife, I'm very happy with mine and I'm an aggressive rider especially in turns, cheap fix that makes a world of difference
Jeff, wish you don't mind my question
What " bottom out " means? And does that fix is fir STL 2014 ?
thanks
wish snoopy or Bob Denman will not step in this :chat:
thanks
"Bottom out" is for example when you hit a light dip or bump in the road and your bike (mainly front end) dips down and bottoms out the shocks or hits the front plastic.
I hope Bob doesn't postwhore here either. :roflblack:
thanks
The spring rubbers aren't really needed on the 2014's, you have adjustable fox shocks on your bike but the answer is yes, the spring rubbers will work in any shock on any Spyder
The 2013 models don't have adjustable shocks.
Thanks snoopy
Snoopy, thanks for the info:bowdown:. Are you OK? :lecturef_smilie:Usually your answers are with special.....flavor:dontknow:.
I'm considering the bump-skid, from your experience, is it worth adding it?
jeff, thanks. Will discuss it with the technician while having the sway-bar installation, tomorrow.
