Thinking about trading my 2012 RT for a 2025 Ryker Rally - Any problems or issues with Rykers?
That's kind of how I look at it. When I bought my new 2019 F3S, I bought it as a sporty alternative to my then touring H-D bagger. I then started to transition it to touring duty. Soon, it was a bagger F3S with Shad side cases and Lamonster Pack Rack-80L top case. I used that so much that I sold my H-D. What I didn't like with the long distance F3S was the high revving 89t rear pulley and lack of frontal coverage. So I sold my F3S and bought the new 2022 RT S2S in the fall of 2023. I did upgrade the suspension/BR Ultra sway bar to sharpen the handling, and when not touring, removing the top case. I also should note that I am a 100% solo rider. After 25+ years of touring, I have lost the desire of the traveling to get to the destination. I have also joined a group of in town retirees who take weekly/2x weekly 125-150 mile rides to a lunch destination. These rides are primarily on County/State roads with very little freeway riding. I haven't enjoyed riding so much in years. Hence the turning desire to a Ryker. I liken it to a Miata. Smaller and more nimble for the type of riding I will be doing. I will add a rack mount to the Max Mount to be able to add a 55L top box so I can use it for weekend over night trips. I'm leaning to a Rally, as for the $1500 difference in cost I feel like you get some nice extras. The Sport certainly fits the title, but I'd need to add a comfort seat to replace the OEM foam they call a seat. I could also add some nice extras to the Sport to make it more sporty. :) Either model will be fitted with the prerequisite sway bar/steering damper to make it more nimble. Decisions, decisions...
Have you ridden one? Given the riding pedigree you mentioned, I imagine you might find it a bit tiny on the road. Although it doesn't lack for comfort or power, you'll need to allow for some 'getting to know me' time in the relationship.👫
Actually, not yet; but I have sat on quite a few. No doubt there will be some acclimation involved. :)
@troop, take a look at Sargent Seats before you spend any money on a BRP seat upgrade. Slingmods is now carrying Sargent too, I think.
Sarah
For someone who rides solo and is planning on adding just a top box like @troop is, that looks like quite the ticket to me. There's even a heated option and a rack option on Slingmods website!
Sarah
I'll take a peek. I did see the Show Chrome version. Thank you
** Just checked it out. I owned a Sargent seat on a past KLR650 and liked it. Go directly to Sargent's website. Use code PRESALE2026 and get $40 off **
** Cancel that, as they also charge the same $40 for shipping. Free shipping/points at Slingmods. **
There is a dealer about 100 miles from my house that has both a new 2025 Rally and 2025 Sport for sale. The Rally is $11,249 (fees incl) + tax/title/reg. The Sport is $9,249 (fees incl) + tax/tile/reg. For me, OTD they would be $12,133 Rally and $10,023. OTD Sport. I'll check them out if the RT S2S sells this week. No diff between 2025/2026 models...
The original Rally rear guard is a bad idea, it's design is more for style than substance. It has a plastic cover strip that sits right behind the rear of the seat to cover the hole left from fitting the Maxmount. I had to remove it for some reason? (To fit the rear passenger seat from foggy memory. :unsure:) Once removed, my lower back got sprayed with dust from the exposed wheel. Plus, the swingarm gets coated in tar, dust, mud, and grime. I bought a full guard from a wrecked Sport and that saved the day,
The Rally has way more features than the Sport, including longer front suspension and higher ground clearance, a better seat, wishbone protection, skidplate handguards, and a Maxmount. (BRP list the Maxmount with the Sport spec sheet on their website, but it isn't shown on any Sport pictures so you'd need to check... it's expensive to buy seperately) You also need to check to see if the Sport has cruise control; specs say it does, but I'm fairly sure the earlier Sports didn't, you had to buy it as an extra.
For me, the extra ground clearance was always going to swing me towards the Rally.
I was able to sit at/look at both models at my local dealer. For the $2K difference of the Rally, you do get the longer travel-compression adj front shocks, comfort seat, Akro exhaust, handguards, grill guards, and the front accent light. In the USA, both models include cruise control and the Maxmount. The Rally has Rally mode and the Sport has Sport mode. The Rally mode is slightly less intrusive than Sport mode. While the Rally has 1" longer suspension travel, the spring rate is softer. I'll likely be a 100% pavement rider, so there's that. For the $1800 sales difference, I could order a seat/hand guards/radiator screen/RLS exhaust/front aux light and have $$ left over for a sway bar, steering damper, and a windscreen that I'd still add to the Rally. I'd just take some time and set frt/rr preload for sag measurements. Sounds like I'm leaning to the Sport, but I'm still really on the fence. :)
Always exciting to get a new vehicle! You seem to be well informed, you'll make the right choice.
When I got my Rally, they had heavy discounts on the RRP. I got a comfort rear seat and backrest, plastic handguard covers, adjustable adventure windshield - and I discovered how Can Am charge like wounded bulls for accessories! With the accessories, I still saved NZ$1,000 on the Rally's retail price, so no complaints. I've since added, steering stabiliser, swaybar, rear guard, reverse gear lever, GPS, 6"Apple carplay screen, Foot rest support for my prosthetic leg, heated grips, wider adventure handlebars, grip puppies, quick access battery terminals for my pneumatic tire pump... what can I say, I'm a Ryker tragic.
Oh, and I cant forget, the humongous socket and requisite torque wrench required to remove and refit the wheels... 300nm requires a lot of leverage!!
I assume you got some quotes on the extra bits you're looking for comparison? Ryker parts are hellishly priced!
Slingmods, Lamonster, and to a smaller extent, Amazon will be my friend. Already have a 50-300 ft/lb TQ wrench and 65mm socket picked out :)
The Ryker is a blast to ride, even long distance (at least for me). But it is pretty much the 180 degree opposite of an RT.
2-UP, the RT is much better. The Ryker struggles 2-Up and is only comfortable for smaller riders
Storage - There isn't any storage on the Ryker, although storage can be added, it is never going to be what the RT provides.
Ride Comfort - Definitely goes to the RT, though the ride on the Ryker is also good.
Maintenance - The CVT requires more maintenance (every 10k belt replacement). Though the Ryker's drive shaft is more reliable and requires zero attention compared to the belt drive on an RT.
Power Transfer - Because of the CVT, the Ryker engine spins high all of the time. This is not really a problem, but for some, it is annoying. The 1330 RT is a more mellow powerplant.
Both rides are excellently suited for their intended purpose. You can modify the Ryker, but it's never going to be an RT. Still, if the Ryker suits your riding style, you will find it an excellent machine.
I bought my Ryker Sport (used) in August of '24 with ~3000 miles, a full complement of luggage, Ultimate seat (now off for a solo Combat seat), floorboards, plus a bunch of other stuff to solely replace my 208K mile Kawasaki Concours because it was getting too heavy for me. It now has 14K miles on the ODO and has carried me on multiple 8 hour straight-through rides since then. It's also my daily driver, so I'm on it practically every day running errands or doing whatever. My wife doesn't ride, hence the change to the solo seat. I do add a back rest for the longer rides that provides a little more comfort and back support, but does make it a PITA getting on and off. Ya takes the good with the bad.
I looked at the Spyders a number of years ago but just couldn't justify the price. Their comfort amenities have vastly improved since then, along with a price to match. In addition, the drive belt was also a concern because I do hit gravel roads every now and again.
I'm quite happy with the Ryker and will probably jump on replacing the CVT belt and drive line fluid changes in a couple of weeks.
