things I would like to see on RT
I'd like to have 2 extra power outlets, one at the back seat (actually, there's already a plug for one under the left passenger handgrip) and one up around the dash. I'd use the rear one for heated clothing and the front one for any accessories (like a GPS or a heated vest). Either one would also be handy for plugging in a battery tender -- wouldn't have to open any lids. Extra power outlets are nickle and dime stuff.
More positive turn signal switch. The existing one is pretty mushy.
Better quality speakers. I have a slight hearing deficit, and I have to crank the current ones WAY up to hear anything (especially at speed), and at that setting, the sound breaks up.
I think, for the RT-S and RT Limited, Tricled's front fender and saddlebag LEDs would be a nice touch.
The stock seat doesn't bother me. I rode BMWs for 32 years, and their stock seats are hardwood planks compared to the Spyder's. For longer trips, I add a sheepskin pad, and sometimes I also add a swatch of bubblewrap under the sheepskin. (I'm cheap!)
Upgrades
Power! 1330cc overhead cam engines should make more power! My KTM has a 1301cc motor with 160 hp. Bone stock! Rotax engines make plenty to power-add some! Add LED headlights, stronger saddlebag hinges, a hand brake, and side bags that hold a helmet (both sides!). Most of all, POWER! Looks fast, is not fast. Make it fast - like 10.5 in a quarter mile fast! Or, faster!
just some smaller less expensive changes
1. I would like to see a power source like a cigarette lighter up in the handlebar area instead of the trunk which is pretty much useless.
2. A cup holder would be nice.
3. a rear brake light in the top center storage box like the one Custom Dynamics makes
4. a mud flap on the rear wheel
5. A heavier sway bar like the others offer by aftermarket sources
6. laser alignment from the factory
7. better quality tires
I'm happy with the belt drive and pretty much everything else.
Hand Brake
think of the time it takes to recognize a problem, then lift your foot, position it, and finally compress.
A hand brake is far safer, quicker and efficient which is what we seniors want and need. Safety please!
Larger top load saddlebags
Top brake light.
Front fender turn lights.
Full radio controls for passenger.
Front brake lever.
attachment.php
Because I have wanted one for over three years, and I attached with Sugru a 3" round flat mirror to the bottom right corner of the left hand mirror. Both our mirrors show vehicles farther away than they are.
I can lean over a bit to see how far a vehicle is behind me. At last! :yes:
A knob that turns on the radio to select stations instead of the lame push station selector.
Actually, I really like that idea. I hate the push button station selector.
And since I have a top rear brake light on my RT aftermarket, I really think they should have those on all RTs. It makes a huge difference.
