thermostat
Look at your pressure cap. If it is not turned to the second detent, it can overflow readily. Also check to see if the fan is coming on. It should come on by 3/4 of the gauge (6 bars). If not, check the fan relay to see if it is fully seated or bad.
I have done all that temp raises over half at high speed it comes through overflow tube
If you are absolutely sure the cap is at the second detent, you have either a bad pressure cap and/or a bad thermostat. A bad thrmostat will usually show overheating on the gauge. A bad cap may overflow at normal temperatures.
