Thermostat / middle hose antifreeze leak question
Ben Burped
I found a puddle of antifreeze under my 2010 RT. After removing all the "Tupperware" and the "frunk" to install Xenon Depot Fog lights, I traced the leak back to the thermostat housing and the U shaped hose that comes into the side. The question is "do I just replace the problem hose and thermostat or do I replace all the hoses while I'm in there"? It's a lot just to get to the thermostat and the other radiator hose. Do I replace all hoses while I'm in there and everything is already apart ? All the hoses have been hot and cold through many, many cycles. I have Oetiker Pliers to remove and install those hose clamps that BRP chooses to use.
Remember to "Live before you die".
