>> The ONLY Road-Legal LED Replacement bulbs <<
XenonDepot
The FIRST Road-Legal LED replacement bulbs - Available in: 1156, 1157, 3157, 7440, and 7443!
Unsure of which bulb to get? - Check out our Lamp Replacement Guide for detailed bulb information by vehicle.
Available in: 1156, 1157, 3157, 7440, and 7443!!
Philips 1156 LED bulb - Road Legal
Philips 1157 LED Bulb - Road Legal
Philips 3157 LED bulb - Road Legal
Philips 7440 LED Bulb - Road Legal
Philips 7443 LED bulb - Road Legal
The web page doesn't have Can-am listed under bikes, will you be including the Spyder?
These LED replacement bulbs will not work on the RT turn signals with or without the CANBUS option.
Are you speaking from experience? The CanBUS adaptor is essentially a load resistor that simulates a load, so that that the computer sees the same draw as a standard incandescent bulb.
Steve
Been there and done that, don't work. The load resistors to mimic the incandescent lamp also get very hot in use and MELT plastic. There is no metal in and around the tail light assemblies to mount the load resistors. None the less. with or without the load resistors installed, Nanny does not like them and fast flashes.
Can these be safely used for the foglights ?
If I need a resistor to mimic the draw of an incandescent bulb, what is the advantage ?
how bout this
If I need a resistor to mimic the draw of an incandescent bulb, what is the advantage ?[/QUOTE
I used this on my 2012 RT works fine and they are ALMOST as bright as HID's....just plug-in N ride!
2x H11 H8 CREE XB-D LED Projector Fog Lamp Daytime Running Light Headlight 50W:thumbup: from EBAY.
They do heat up, but what was the rating on the resistor you used?
ThreeWheels - for maximum light output from your fog lights I would suggest looking at this LED bulb (assuming you don't want to go with an HID KIT):
Philips has H11 / H8 / H16 LED Fog bulbs which replicates the beam pattern of an OEM halogen bulb (the only LED bulb that has been properly tested) - Here are some pictures of the bulb:
Steve
Just got some pictures of the Philips 7443 LED bulb installed in a Lexus GS:
Stock 7443 bulb:
80-80_img_3717_d7949d436fd5a1d013c1e090c299d3dce2af12ee_f9ef4f78b113af5d3b32f2c152fb6aa4685bdc6b.jpg
Philips LED bulb:
80-80_img_3715_0921b426a49c2f83f7418872d6935b778c3f94e3_46ea1354ecad600c3965029bf52160b8f9f4f8eb.jpg
80-80_img_3745_ca9411b746cacf5acbe473895a076028370d237c_caef1f5735b827f0f5baea017ab969a66f8994d1.jpg
80-80_img_3747_df5ff87acfbaaee78e595c062218b9a3d3dde353_459a823f4afb987ea228e20c39f0cf61b6798b7e.jpg
80-80_img_3715_0921b426a49c2f83f7418872d6935b778c3f94e3_73f3dce024099dd234a390db4fb4cbb3e9645063.jpg
80-80_img_3744_8690882d2846d467cbd96f9982a6ef206906d480_25bd8d16323cc4c502278258389a26d8d0478471.jpg
Notice how well they distribute the lights? Philips designed these LED replacement bulbs to maximize the use of the reflector bowl - just like it’s designed to be used!
Make sure to check out easy to use HID/LED/bulb Lamp Replacement Guide to see what bulbs your vehicle uses - SPYDER INCLUDED.
Steve
