The motorcycle makes a friction noise. help..T_T
kongdoly
I went to the Can-Am dealership, but the staff said they don't know.
It is not the current brake sound.
A grinding sound is heard. KRIRIRIRIRIRIRIRIRIRCCCC
It makes a noise when first starting up.
Even when the throttle is slightly closed in N gear, the noise is heard.
A sound is heard when driving at a speed of 0 to 10 km/h.
What is the problem.. please help.. please
https://youtube.com/shorts/9ReqH4YAGDg
I ......
Kongdolly, you'll probably get more responses if any viewers of the vid DON'T hafta sign in &/or do anything else in order to watch it. :rolleyes:
! Sign in to confirm your age
Sorry, but without the vid, which is somehow restricted ^^ then no-one's really going to know what your problem is/sounds like?! :gaah:
Is the noise a brake noise that ONLY happens when the Spyder starts moving, or is it a noise that starts with the engine, continues as you idle, and maybe gets worse as you start moving? :dontknow:
Changed to full disclosure. A strange noise is heard during the early start. It's the first time I've driven well at 20,000 miles and this is the first time I've heard this sound. T_T
Hmmm, not sure that I really could hear anything too much untoward in that vid, except maybe a bit more huffing from the exhaust than is probably ideal, but that could easily be due to wherever the mic is sited &/or my gradually more compromised hearing... or maybe it's a lost spring &/or gasket; possibly a crack or leak somewhere in your exhaust that's making the noise you're concerned about?? :dontknow:
However, while I know this thread is in the F3 section, and you've asked before about F3 Tires & Rim Widths (Feb '23) and about replacing the HCM Filter on a 2018 F3S (Mar '23), but you've also posted earlier on (Jan '23) about trying to increase the ground clearance on a 2021 Ryker Rally, so I guess I should really also check to make sure that I know which bike you're talking about... The Ryker of the F3? :rolleyes:
And while we're on that ^^ subject, it really would help readers and mean that you don't need to absolutely clear in every post what year/model Spyder/Ryker you're talking about if you added your current ride info to your sig line as requested in this sticky:
https://www.spyderlovers.com/forums/showthread.php?146210-A-Request-Passed-On-To-All
;) Just Sayin' :cheers:
And repeating that I couldn't really hear anything much wrong in that vid. :dontknow:
Sorry. :opps:
New noises are usually not a good sign. Having said that. I don't hear anything that would concern me. Do you hear it in this video?
kongdoly -- does the noise sound more like a squeak or chirp? Did you change to another brand oil rather than BRP? Does the noise change when turning your handlebars while stopped?
