The dreaded orange check engine screen
Browny
Driving home from a PGR event,. I started to smell gas. Bike ran rough for about a half-mile, then screen went back to normal and ran fine for about two miles and it happened again. When I got her home, I went to back her in to her parking spot and she cut off. I turned the key off, let her set for a few seconds, restarted and she acted like nothing had happened. A 2011 RT with 3900 miles on the clock, I hope it is no anything major. Bought it used. Any Ideas. No codes thrown. Hope its a hose leak!
Did you check for codes? With the key on, push the mode, set and turn signal cancel buttons at the same time. If there is a problem that is still active the codes will show on the screen. If it was just a momentary blip the screen will be blank.
