Thanks to Phil's modes
frenchek
Thanks Phil, great idea adding the exhaust fan to the belly pans. mine is a 2013 rt so because of the frame differences I had to set the fan up a little and build a shroud up to it. IT WORKS GREAT. I don't have the heat issues that other 13,s have, but the fan takes out the heat under the tubberware as I wanted. good thinking-thanks again
tim :yes::yes::yes:
tim :yes::yes::yes:
Would like to see some pictures & parts used. Fellow RT/s owner
fan
:nopic: You can't put that up without pictures!
Sorry guys, don't have the capabilities to do pictures. If you look thru the posts you will find PHIL's MODES, its one of the last ones. he has pictures and the fan type and where to get it. Phils spyder is a 2012 so the frame is different, mines a 2013 rt. the only difference with the install is that you can't anchor the fan to the belly pan, there is an excisting flange there, already with a hole in it and you have to add a leg. because the fan doesn't sit on the belly pan you have to make a collar to direct the air out.
keep in mind, this not a cure for the excessive heat that some have had to deal with. this was strictly to cool down the inside of the tubberware and hopefully extend the life of the wires, hoses etc. The fan only has about a 3.5 amp draw, buy moves about 2200cfm. for me--it works very well. You could get a smaller fan and do it just like phils, but I really couldn't find one that had the cfm rating and the low amp draw.hope this helps
tim :yes::yes::yes:
Happy to help!
http://www.spyderlovers.com/forums/showthread.php?24907-Phil-s-Mods&p=717172&viewfull=1#post717172
Lots of pics.
In case that doesn't take you right to the post, it's post #209 in: My Spyder Mods; Phil's Mods
