Thanks JT
Schlic
Received my Dual Fill w/Gauge yesterday JT. Checked it out this morning and it's a great item. Like we talked about in the PM, it sure makes it a lot easier to top off the rear tire also. #'s on gauge are easy to read. Thanks again...:thumbup::thumbup::thumbup:
The same experience I had . . . everyone with a Spyder should have one . . . it is the ONLY way to ensure both front tires have the same pressure . . . exactly! Thanks, JT!
Jt how much you charging for this setup?
The Dual Fill DF-2 with gauge is 74.50 delivered and the Dual Fill DF-1 without gauge is 58.50 delivered. If you use shop air (greater than 30psig) then you should use the DF-1. Most people use a bicycle pump with the DF-2. As some have found either one can be used on the rear tire as the special air chucks have check valves built in.
Everything is shipped free in the USA... sorry but international orders will have a surcharge for the extra postage the USPS charges me. I'm happy to ship almost any place in the world!
JT
Can't wait...welll guess I'll have to...
Thanks, it took quite a while to find all the right components. Some of the first things I tried didn't not meet my high expectations but I finally found all the right parts to put together a good tool.
Thanks
JT
Decided this and a tire repair kit were my this year "tools" I needed to add...so order placed. Thanks JT...:thumbup:
