Thanks for the heads-up on steering issues!
Tom in NM
On Saturday, I put around 300 miles on my Spyder and experienced a case of the steering problems some others have mentioned. Nothing serious, but I will be taking the Spyder in and have it looked at.
It happened three times, highway, straight road, 75-80 mph. The first time, I saw some road debris ahead and lightly turned to the left to avoid it. It was a smooth course correction - if 12 o'clock is straight ahead, my turn was an easy turn to 11 o'clock. When I went to correct back to the center of my lane, the steering felt 'stuck' - like I was tracking on a road hump or pavement groove, it didn't pull, but it was 'locked' on the track it was on. It didn't take much effort or muscle to 'un-stick' it, but it when it released, I was exerting enough pressure for it to over-correct and the Spyder jogged to the right. Since I had a full helmet on, earplugs, and was at 75-80mph - I did not hear anything. At no point did I ever leave the lane I was in. I didn't try and go further left, that would have taken me out of my lane - so I don't know if it was locked for turning further to the left.
When trying to turn to the right, it felt like when you separate magnets - they are firmly attached, then when the pull you are applying overcomes the magnet's force, your hands fly apart faster and further than you expect. The binding force is there - then instantly it is not there.
As I said, this happened 3 times - over the course of 20 miles of the ride - all the conditions were the same as I described above. I stopped at a rest area, considered pulling the DPS fuse, but didn't. After that, no further events. I kept my speed down for a little, but finished the ride at normal riding speeds. None of the events were scary, but I did feel I was contending for control when I wanted to go right. After it would "un-stick" steering was instantly very easy and 100% responsive (right & left) - but there would be an over correction based on the sudden 'release' and the force I was applying.
I was out on Sunday for about 100 miles and experienced no steering issues.
My experiences were not anywhere near as serious as what others have related, more like the irritation of a stretch of very bad road surface, unsettling - not scary. But, THANK YOU, to all that posted your experiences - the instant it happened, I knew what was happening, what I had to do to correct it, what to lookout for and some possible on-the-road fixes. Thank you all! :thumbup:
And yes, Firefly, I will be reporting this to BRP and NHTSA. :D I will be having my dealer look at it next week when I take the Spyder in for its 6,000 service. Sooner, if it starts acting up again.
For those interested: 2008 SE5, DPS update (1st Update) done 4/20/09 with 600 miles service, no performance problems or steering issues before or after - until 11/28. No second update. No electrical mods. All fuses felt snug. Tires at 19psi.
Thanks again to everyone for sharing your experiences! It helped me.
Tom
Hey, Tom. It sucks that you had the problem but you're right... get it fixed. It only gets worse from here. At the end... on mine... there were times I didn't think I'd be able to make a correction. It was that baaaaaad.
Tom
Thanks for the Description Tom!! I put on another 100 miles on some of CT,s nicest back roads even though it was only 52 degrees Sunday!
Darn Spyder is giving me More withdrawal pains than my 2 BRP Jetskis it shares the garage with because its going to be a Long, Cold,:gaah: Snowy :gaah:winter here in the Northeast.:ohyea:
Great job Tom, so glad to hear u were able to identify what was happening and do what was needed to correct it safely. Do take it in and have it fixed. Hopefully you will have it back soon all fixed and ready to ride. :thumbup:
:agree: Gets worse real quick. Mine started slow and was just as you described. Even had a few days of no issues which was enough to give a false sense of security. Then it hit real hard in the middle of a rain storm. It was locking everytime I turned the bars. I had to limp it all the way home on side streets.
Glad to hear the threads helped and that you made it through just fine.
Glad to hear it was not as serious as some have posted about, and that you are going to take it in for repair.
Best of luck with it.
After 51 years of CT weather, I finally had enough and moved. I visited a friend here at the beach and 4 months later moved here in 2001 and have no intentions of returning to CT. If my brother's want to see me, I tell them the planes fly both ways. But, getting them out of CT, is like pulling teeth, if they had any of there own. :roflblack:
My friends and I loved riding the back roads, Talcott Notch or Old Mountain Rd to Rt 10, 10 to Granby, to 20, to Barkhamsted, 44 to Winsted, to Rt 8 to New Boston in the Berkshires or the old Rt 9 to the beach. Cruising through Clinton to Old Saybrook, getting on 95 to cross the bridge and head for Old Lyme and sometimes to New London.
This was back in the mid 70s and not long after I sold my BSA in 1977 and haven't ridden until just looking at a :spyder:The next thing I knew, I was signing the papers. I just can't go look, I end up buying. After 32 years, riding just never got out of my blood. No regrets though with the steering problem I had and after years of being responsible, I'm back to being a kid again.:D
Steering
Tom
Keep us posted--I am interested in what they do to fix the problem.
Michael:doorag:
Glad it wasn't bad for ya!:thumbup: I'm wondering if the 1st update has caused a communication glitch somewhere in the :spyder:
It was my understanding that the recall (1st update) contained instructions to remove the deadband at the steering center, so there would not be a lag in the power steering initiation. My gut feeling is that this exposed a mechanical, electronic, sensor, or software weakness that went undetected up until then. My experience with PID controls says that they aren't usually too fond of zero deadband. I suspect this may be similar. My opinion and a dollar will buy you a burger at Mickey Dee's...and nothing more, BTW. :D
Yep! See but youi said it with detail cuz you are a gearhead! I kind of meant to say that. :2thumbs:
Just seems like many people are having issues after the 1st update and it seems more like 08's than 09's.
Steering Issues
Your experience sounds familiar;)
Glad it was only a minor issue so far
btw, my :spyder:is running better than ever - or at least since the first update- I think it's actually better...
so far . . . . . .
. . . . I am impressed.
I posted the start of this thread on Monday. On Tuesday Carlo from BRP contacted me - before I contacted them. I provided the necessary information and an incident File was set up for the Service Department to consult and interface with BRP on. Carlo was helpful and very understanding.
I set up a drop off time with the Service Department. ( a different one that I have been dealing with ) So far, they seem knowledgeable and were exceptionally nice to deal with. I dropped off the Spyder late yesterday (Wednesday) and they felt I would probably have it back to me, maybe, by Saturday.
Since the 3 minor steering incidents I mentioned in my posting, the Spyder has not exhibited any further problems in the last 300 miles. But, based on what ataDude and jsmiley experienced - and what Carlo recommended, I took the Spyder in a little earlier than I had planned.
As I said, I am impressed with everybody's "Pro-Active" concern and the serious attention they are giving this. :thumbup:
Thanks for all the support and I will keep you informed.
Tom
my Spyder is back . . .
Well, I got my Spyder back yesterday. Everything seems fine.
The shop could not duplicate or trigger any steering issues after doing the update to the update and inspecting the steering gearbox or testing the DPS. I took the Spyder out for a good run, about 50 miles - starting on regular streets to check out any changes and ending up on the expressway. It ran as good as it did when I took it in ( which was very good ) and there were no steering glitches.
By the way, this "new" dealership I went to, was great to deal with. A pleasant change from my past experiences.
It would have been nice if there was a definitive test that would show that a specific hardware/software/configuration/condition would cause the steering issue - or not. But, little in the world ever is that "Yes" or "No" and I will continue to try and stay on guard - especially in the conditions where I experienced the problem in the past and where others have also run into the issue.
Thanks to all for their help and encouragement. I hope all you other riders with the same problem are back on the road soon, too.
Tom
