Nito
Hi Dave,
If you're referring to putting the rear sensors on the front, sure it'll prevent any traction control kicking in and allow the rear to spin up, but this isn't where I'm coming from. It would be nice for a bit more slip but I don't want it to spin up and high side.
Doing the above wouldn't change the 'stability' side involving automatic application of braking or a situation where one wheel is off the ground and so the two fronts are spinning at different speeds again causing application of brakes and cutting of power anyway. Imho, automatic braking is fundamentally wrong and I've had the same issue with cars that feature stability systems. It's great for people who bimble about and are scared of lifting a wheel accidentally, but terrible for owners who do push things a bit further. If you are pressing on its not safe to have VSS take over, because it can react both unexpectedly and inappropriately. I'd like the ability to switch off stability but retain ABS and traction control in differing degrees.
As it stands I'll just have to learn to ride around it. It's not a massive deal in the grand scheme of things and the bikes are great fun anyway, but in the search for continuous improvement it's one of the few things I've noticed that I really don't feel comfortable with (in 350 miles of ownership anyway) and never have on cars in the past. I fitted an override switch to my old Subaru H6 Legacy Outback because the Vehicle Dynamics Control was terrible and the car was infinitely better without it, far more predictable/consistent when pressing on and ironically more stable! The other thing I've noticed is under hard braking (tested a couple of times to see how it'll react in an emergency) the bike doesn't seem to pull up squarely, it seems to pull to one side. I'll need to monitor this, might be down to everything still bedding in.
Cheers
Nito
Hi Dave,
Cheers
Nito
