Tank Bag?
Garf
On 2 wheeled motorcycles we call it a tank bag.
What would you recommend for a 2017 RT "tank bag"?
Something with a clear map pocket and room for "stuff"
Thanks
I've seen what I remember being called a "glove box" bag. Can't recall which of the home page vendors carries them but I'd check Lamonster and Value Accessories for a start. Don't know if what's available will be large enough for your needs but it's sure worth a look.
Has a clear map pocket to go on top, but I already know where I am going most of the time.
BRP makes one that lays on the glove box. Has a nice storage area and a clear map pouch. I really like it, but if you get one, be sure to put something under it to protect the original paint. The vibration and just general use will leave small scuffs. Sorry, I don't have a pic on my computer, but I bought ours at the dealership. I think it was about $70.
We had those on our 2008 and 2009. They were very nice. That was an original BRP accessory catalog item back then.
Yeah, put one of them stick on thick pad things under mine. It has a foam pad on the bottom, but it does move around some.
Like the "Glove Box Bag"
I own the small "glove box bag". The clear window is way too small for a map, but I can put directions or pieces of a map in it. More importantly, I can put small items that need to be close in the bag. Things like toll cards, change, a hot dog etc. It works for me.
~Sandee~
~Sandee~
I have the small 'glove box bag' mounted on my RT too, you can put lotsa things in it - see my avatar pic! :ohyea:
IIRC, that little bag was originally sold by BRP as something for the GS/RS/RSS/ST's, with a couple of different attachments included to suit fitting it to whichever model you had.... it wasn't hard at all to slightly modify the front attachment so it'd fit the RT, & all it took at the rear end was a short adjustable strap around the main frame spar with a short trailing length & a clip that passed up between the seat front & the glove box rear that made it easy enough to release so that I could still lift the 'glove box bag' (once Max was out of it, of course! ;) ) and get into the glove box proper when I needed to. I did also cut a tiny slot in the rear base of the bag to pass a strap thru that allowed me to connect a strap onto Max's safety harness so he couldn't fall off. ;)
And I also had a bigger but very similar 'pet carrier' bag (it was actually the smallest we could find, Max weighed in at less than 5 pounds dripping wet!) so that he could travel in fully enclosed comfort if he felt like it on longer trips, but he rarely did that. Most of the time he liked to at least have his head out in the breeze to get the wind in his face - he was very proud of his doggles & riding jacket & he loved to show them off to other road users as we passed. He rode like that with us on a variety of machines for more than 15 years, and now that he's passed on, he's very much missed. :(
I doubt that BRP will still be supplying that particular tank bag, simply because the Spyder models it was originally intended for are no longer produced, but it really shouldn't be all that hard to find a suitably sized tank bag with attachments that either suit or could be readily modified to suit fitting it onto an RT. You could even secure it forwards with a strap around the steering shaft, and there's a relatively easily accessed main frame spar under the front of the seat that can secure the back end.... you just hafta think a little outside the box, cos there won't be too many tank bags made specifically for a Spyder RT - after all, they've already got a glove box & more storage than some sports cars! :thumbup:
Have fun & Good Luck! :cheers:
Great responses. GPS is great, but I also like to refer to a printed map' (old guy, old school) so the one from Cyclemax looks to be a good choice.
Thanks to all.
Thanks to all.
Me to on the printed maps. I bring a Rand McNally along for the ride. It goes into the rear trunk. I study where before the ride. If I get confused, I pull over and look at it again.
I used to put a "copy" of the page I am using in the RT glove box....but the new F3 does not have one of those.
On a trip to Texas a few years ago ( on a two wheeled BMW with a tank bag) I photocopied the pages of the route I was taking and just swapped them out as I went along. This gave me the opportunity to say "that road looks interesting" and divert from the GPS.
I used to wear the old tan color deer skin gloves and write the road numbers where I was to turn on the back of the gloves with a Sharpie. Been Florida to Maine and back several times doing that. Gloves would be full of writing and somebody would always ask what it was.
GPS of course.
I have one of the Hopnel's that strap onto the glove box door, and the top small one with the clear top has an attachment system that I turn to the left and it comes off and I have a large map pocket that goes on in it's place. Can't remember where I got it though. It's a glove box bag system.
Egads Peter, you haul you dog in this thing? I'm thinking I need more room as in the 2020 RT/RTL for two up, maybe my thinking is warped and I need to reconsider.
