Tail light bulbs
ace2002
How do I get to the brake and tail light bulbs to change them on an rt? Can I tap into the wires to run a trailer?
In order to properly use a trailer, you need to let the dealer do it. Just had my RT done. Took it and trailer to dealer to insure it all worked properly. Also, the new Can Am trailer, which I don't have, uses a square four pin connector instead of the nine pin they used to have. I'm not an expert but I think you have to get the trailer wiring harness and plug it into the computer. Thus when you hitch up the trailer, the computer knows to that the voltage or current drain is ok and helps with ABS. But of course, you need to have RT in trailer mode. I would not tap into anything unless dealer said I could. Good Luck and God Bless!!!!
Mike
Hooking up the trailer doesn't do anything. That's why you have to manually select trailer mode with an SE. BTW, the SM doesn't even have trailer mode. Hooking a trailer to a Spyder depends on a lot of things. Post the details or PM me and I'll try to tell you the choices you have.
Sent you a PM:bowdown:
