T-Valve Stems Tightening Torque?
Mjhitman
I know this should be a simple answer but here goes anyway. I just got the CM1044 T-Valve Stems from Cyclemax for my 2016 RTL. Putting a new rear tire on and want to upgrade to the T-Valves stems for my FOBO sensors. Any input for the amount of torque for the two nuts on the inside? Thanks in advance!
You might ask this on a GL1800 darksiders forum. They use them a lot. I did mount a single core metal stem that I had as an emergency repair for a ripped-off stem on our garden tractor. Just tightened enough to see the rubber gasket fully seat on both sides of the rim.
