PMK
It sucks, to have a machine, that doesn't work properly, I would (after reading this complete thread) go with the option PMK suggested, Look for a bad hub, it isn't that far fetched.
Easy to check, Remove the wheel, set up a cardboard box, next to the hub, and while holding a ruler, slowly spin the hub, if you see any movement in the hub/ brake rotor, that would be the culprit.
Might be even something stupid, as the wheel not seated correctly, If you change tires from left to right, just to test...
The method of checking the hub / disc you mentioned is somewhat difficult to do in a simple accurate way. The reason being is that the brake disc is not part of the hub, like on old cars. This requires any checking to be done at the hubs small diameter, after removing the brake caliper and brake disc.
By spinning and watching the wheel it could indicate a concern to investigate further, which could then be checking at the hub.
Great suggestion though.
