sway bars
do sway bars make a big difference in handling ?
Yes they do. If you do a search, you will find dozens of threads and countless comments on this topic. Specifically, BajaRon sells a sway bar that dramatically improves handling of the Spyder.
Pam
Ah ha...!!
I see you have not done your homework..:lecturef_smilie: Oh :cus: yeah..!! A search here would conger up a mirad of posts praising the BajaRon swaybar and hiem joints...if your on the fence..jump off you will join the ranks...:roflblack:
Yes yes and yes
I had the Bajaron swaybar and the hemi links installed. Also had a laser alignment done and it truly feels like a different bike. Definitely money well spent. :thumbup:
From all that I've heard, the answer is definitely yes.
I bought Ron's w/links a couple of months ago, but haven't found a way to get my spyder lifted high enough to actually get them installed yet, but hopefully once the rainy season starts I'll find a way...
-Fratz
Swaybar Questions...
I'm soon (budgeted next month) going to order a BajaRon's sway bar and install it myself. 2010RT...the question is should I also get the links...on my machine, are OEM plastic like others (defective) mentioned elsewhere
Also, if I get the swaybar now, and wait to get the links at a later date, how hard is it to install links to an already installed bar ?
TIA
