BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
THIS ANSWER
JIM ::bdh:.......Mike ......:gaah:..:roflblack::roflblack::roflblack:
Anyone evaluating the difference between one anti-sway bar over another needs to know what to look for. Additionally any difference you notice will be highly dependant upon the way you ride. If you ride slowly or don't take corners aggressively you may not notice any difference at all. A higher performance anti-sway bar will reduce body roll and lean to an extent when taking corners. The faster and more aggressively you ride the more you will notice the difference.
A higher performance anti-sway bar should not produce any undesirable side effects so there is no significant downside unlike other modifications. For example you can also reduce body roll with shocks with a stiffer spring rate but at the expense of a harsher ride. So if you want to reduce body roll try out a performance anti-sway bar first. If you don't notice any difference then you probably didn't need this modification for your style of riding which is perfectly ok, not everyone rides aggressively.
