sway bar
Cindi
I installed my BajaRon sway bar today. The bar I took off looked exactly the same as The BR bar except for the aluminum things.
Interesting..!!
don't know what roadster or what year you have. RS stock bar is much thinner and different bends. Did you buy your bike new or used? May have been changed. There are other bars out there Ron's are mostly red. Are they the same thickness? :dontknow:
On my 2012 RSS the stock bar was the same size as the red Ron bar though its not the size that matters he uses different steel with higher tinsel strength and smoother rebound that grounds the bike better.
If you have an RSS you may want to reduce the preload on the shocks for a smoother ride and better cornering.
Mike
