stmike 1800
Does any one know the difference between the 2017 sway bar 706201544 and the 2018 706202800 ?
The bajaron is 14mm and if i measured my right the stock 2018 RTL is 16 mm.
Yes i do know there are difference in the tensile strength of steel , but my bikes must be made of lead .
The sway bar should be your number 1 first upgrade. I just purchased a 2015 RTS with 2700 miles about 2 weeks ago. I've ridden motorcycles for 50 years and have already gotten nervous a couple of times on the RT with respect to how the factory sway bar doesn't hold a line in a curve as good as it should. I purchased the BajaRon Anti Sway Bar $288 shipping included and installed it 2 days ago. This was the best purchase I could have made for the spyder. It is like night and day for curves and handling on the interstate with wind buffeting from other vehicles. I think it made such a difference I just don't understand why BRP doesn't put this level of anti sway bar on the spiders from the factory. This is one purchase you will never regret making.
I rode RS #610 for 45,000. I rode RS #106 for 30,000 miles. I moved 'up' to a 2017 RT and the difference in handling is scary. The RT is definitely an interstate cruiser and does that well.
So you changed your sway bar. Did you change the links? I heard that they will break with a more robust sway bar. Any truth to that. I suspect that BajaRon has it covered one way or the other.
Then there is the factory alignment issue. I had mine checked by Squared Away and they indicated it was right on. Is there some mod people are making to the alignment to improve the handling. I am not likely to change my alignment without a LOT of research.
Mean while I will enjoy my Rt..until I need to make a turn
I test drove spyders with and without sway bars - there was a world of difference between the two.
I'm pretty sure that you don't understand this correctly.
I think they ALL have a sway bar, at least recent models, and the replacement is just stiffer.
